Jupyter Notebooks
Jupyter Notebooks are documents which can contain live (Python) code, equations, visualizations and narrative text and can be used as an intuitive interface for OGS projects. The following video gives an introduction to using OpenGeoSys with Jupyter Notebooks:
Jupyter Notebooks container environments
You can start with pre-defined container environment from one of the images
With Docker:
docker run --rm -p 8888:8888 -v $PWD:/home/jovyan/work --user `id -u $USER` \
    --group-add users quay.io/jupyter/scipy-notebook
This mounts your current directory into ~/work inside the container.
Windows notes
The above command only works when you run Docker from within a WSL2 Linux shell!
  • Install Docker Desktop on Windows, it automatically configures WSL2.
  • Install a Linux distribution from the Microsoft App Store. We recommend Ubuntu 22.04.
  • In the Docker Desktop application under Settings / Resources / WSL integration add your Linux distribution.
  • Open a command prompt in your Linux distribution (At the start menu type the name of the distribution) and run the container.
    • If your current working contains spaces write out $PWD, e.g.:
      ... -v /c/Users/My\ Name/working/directory:/home/jovyan/work ...
With Singularity:
singularity run docker://quay.io/jupyter/scipy-notebook
Open the specified URL shown in the command output in your browser, e.g.
http://127.0.0.1:8888/lab?token=xxx
You may have to modify the IP address if this is running on a remote machine.
Install ogs
Click on Terminal and install OGSTools (which also installs ogs itself):
pip install ogstools[ogs]
You install other Python packages too. Please note that this is a temporary installation. If you stop the container the manually installed packages will be deleted.
