We solve the Poisson equation:
$$ \begin{equation} k\\;\Delta h = f(x) \quad \text{in }\Omega \end{equation}$$w.r.t boundary conditions
$$ \eqalign{ h(x) = g_D(x) &\quad \text{on }\Gamma_D,\cr k\\;{\partial h(x) \over \partial n} = g_N(x) &\quad \text{on }\Gamma_N, }$$where $h$ could be hydraulic head, the subscripts $D$ and $N$ denote the Dirichlet- and Neumann-type boundary conditions, $n$ is the normal vector pointing outside of $\Omega$, and $\Gamma = \Gamma_D \cup \Gamma_N$ and $\Gamma_D \cap \Gamma_N = \emptyset$.
We solve the Poisson equation on a circle domain with radius $r = 1$ with $k = 1$ w.r.t. the specific boundary conditions:
$$ \eqalign{ h(x,y) = 0 &\quad \text{on } (x^2 + y^2 = 1) \subset \Gamma_D,\cr }$$The solution of this problem is
$$ h(x,y) = \int \int f(\xi, \eta) G(x, y) d \xi d \eta, $$where $G(x, y)$ is the Green’s function. For the example at hand $G(x, y)$ is:
$$ G(x, y) = \frac{1}{2 \pi} \ln \sqrt{(x-\xi)^2 + (y-\eta)^2}. $$With a nodal source term of 1 at $(0.0, 0.0)$ the analytical solution is
$$ h(x,y) = \frac{1}{2 \pi} \ln \sqrt{x^2 + y^2}. $$The main project file is square_1e6_with_nodal_sources.prj. It describes the process to be
solved and the related process variables together with their initial and boundary conditions as well as
the definition of the nodal source term. It also references the mesh and geometrical objects defined on
the mesh.
The geometries used to specify the boundary conditions and the source term are given in the
square_1x1.gml file.
The input mesh square_1x1_quad_1e6.vtu is stored in the VTK file format and can be directly
visualized in ParaView for example.
ogs circle_1e6_axi.prj
It will produce some output and write the computed result into a data array of the written VTU file.
| Edit
this page on
