Volumetric Source Term
Equations
We start with Poisson equation:
$$ \begin{equation} \- k\\; \Delta p = Q \quad \text{in }\Omega \end{equation}$$
w.r.t boundary conditions
We solve the Poisson equation on a square domain $[0\times 1]^2$ with $k = 1$ w.r.t. the specific boundary conditions:
$$ \eqalign{ p(x,y) = 1 &\quad \text{on } (x=0,y) \subset \Gamma_D,\cr p(x,y) = 0 &\quad \text{on } (x=1,y) \subset \Gamma_D,\cr k\\;{\partial p(x,y) \over \partial n} = 0 &\quad \text{on }\Gamma_N. }$$
and the source term is $Q=1$.
$$ p(x,y) = - \frac{1}{2} (x^2 + x) + 1. $$
Input files
The main project file is square_1e2_volumetricsourceterm.prj. It describes the processes to be solved and the related process variables together with their initial and boundary conditions. It also references the bulk mesh and the boundary meshes associated with the bulk mesh.
Running simulation
ogs square_1e2_volumetricsourceterm.prj
OGS writes the computed results (pressure, Darcy velocity) into the output file square_1e2_volumetricsourceterm_pcs_0_ts_1_t_1.000000.vtu, which can be directly visualized and analysed in ParaView for example.
The output on the console will be similar to:
info: ConstantParameter: K
info: ConstantParameter: p0
info: ConstantParameter: p_Dirichlet_left
info: ConstantParameter: p_Dirichlet_right
info: ConstantParameter: volumetric_source_term_parameter
info: Initialize processes.
info: Solve processes.
info: [time] Output of timestep 0 took 0.000145912 s.
info: [time] Assembly took 0.000147104 s.
info: [time] Applying Dirichlet BCs took 1.81198e-05 s.
info:    iteration: 11/10000
info:    residual: 3.965614e-17
info: [time] Linear solver took 7.79629e-05 s.
info: [time] Iteration #1 took 0.000268221 s.
info: [time] Solving process #0 took 0.000288963 s in time step #1
info: [time] Time step #1 took 0.000308037 s.
info: [time] Output of timestep 1 took 0.000105858 s.
info: [time] Execution took 0.00692892 s.
info: OGS terminated on 2018-10-12 06:30:13+020
Comparison of the analytical solution and the computed solution
The numerical solution shown in the following picture is almost a linear gradient:
The line plot along the $x$ axis shows that the solution is a quadratic function and is in very good agreement to the analytical solution:
The difference between the computed solution and the analytical solution is in the range of machine precision and therefore almost negligible:
This article was written by Tom Fischer. If you are missing something or you find an error please let us know.
