SimplePETSc
The following shows running a simple steady-state diffusion benchmark running on 2 cores.
prj_name = "square_1e1_neumann"… (click to toggle)
data_dir = os.environ.get("OGS_DATA_DIR", "../../../Data")
prj_file = f"{data_dir}/EllipticPETSc/{prj_name}.prj"
command = f"mpirun --bind-to none -np 2 ogs {prj_file} > out.txt"
print(command)
run(command, shell=True, check=True)
mpirun --bind-to none -np 2 ogs /var/lib/gitlab-runner/builds/F1XUyv4cx/0/ogs/ogs/Tests/Data/EllipticPETSc/square_1e1_neumann.prj > out.txt
CompletedProcess(args='mpirun --bind-to none -np 2 ogs /var/lib/gitlab-runner/builds/F1XUyv4cx/0/ogs/ogs/Tests/Data/EllipticPETSc/square_1e1_neumann.prj > out.txt', returncode=0)
mesh_series = ot.MeshSeries(f"{prj_name}.pvd").scale(time=("s", "a"))… (click to toggle)
labels = [f"{label} linear interpolated" for label in ["pt0", "pt1"]]
ms_pts = ot.MeshSeries.extract_probe(mesh_series, points_coords)
fig = ot.plot.line(
    ms_pts, "time", ot.variables.pressure, labels=labels, colors=["b", "r"]
Generated with Hugo 0.147.9 in CI job 639840 | Last revision: November 9, 2021
