Benchmark documentation can also be given in form of Jupyter Notebooks, see Jupyter notebooks as documentation for details.
PATH
. Attention: Use the extended version: e.g. hugo_extended_0.64.1_Windows-64bit.zip
ogs/web
yarn
and yarn build
once (this will install required CSS and JavaScript packages)hugo server
As you make modifications to the site it will be rebuild and the page in the browser gets reloaded.
By using hugo new
you can create a new page with the correct frontmatter for that kind of page:
hugo new docs/benchmarks/elliptic/groundwater-flow-dirichlet/index.md
content/
and determines the URL of the pageOr you can simply create a new index.md
-file in the correct location and fill it by yourself. Prefer to use page bundles when you want to add other assets, e.g. images, to the page.
content/
├── docs
│ ├── my-post
│ │ └── index.md
This page will be available at the URL /docs/my-post/
and the content of the page is in index.md
The are submenus (shown in the left sidebar) for specific sections such as for benchmarks. The submenus consist of groups (e.g. Elliptic) and page entries. Groups are defined in config.toml
[[menu.benchmarks]]
name = "Elliptic"
identifier = "elliptic"
weight = 1
To add your page to a group as an entry add the following frontmatter:
weight = 101
[menu.benchmarks]
parent = "elliptic"
weight
specifies the order of groups and pages in ascending order (top ->
down).
We use Markdown for the actual content. Hugo uses the GoldMark Markdown parser with the following additional markdown extensions:
Use regular Markdown syntax:
The path to the image is the relative path to the current page bundle.
You can add size attributes to the filename with a #
-character:
Possible size values are one-third
, one-half
and two-third
Equations can be set with typical LaTeX syntax by using MathJax. Blocks are defined by $$
at the beginning and $$
at the end of the block or by simply using a LaTex environment like \begin{equation}...\end{equation}
. Inline math uses one $
as the delimiter. For more usage instructions see the MathJax LaTeX help.
Files belonging directly to a page (e.g. images shown on that same page) should be added directly. Other stuff such as linked PDF files, book chapter input files should be uploaded elsewhere and linked to. You can ask @bilke to host these files for you (on Azure cloud storage).
Bibliography items from Documentation/bibliography/.bib can be referenced by their id (always use lowercase ids) with the bib
-shortcode:
{{< bib "kolditz2012" >}}
The bib-file has to be converted into a yaml-file with the pybtex-convert-tool:
pybtex-convert Documentation/bibliography/ogs.bib web/data/bib_ogs.yaml
pybtex-convert Documentation/bibliography/other.bib web/data/bib_other.yaml
This yaml-file is then used by the shortcode.
ALGOLIA_WRITE_KEY=XXX node_modules/.bin/hugo-algolia --toml -s
Generated with Hugo 0.96.0. Last revision: June 28, 2022
Commit: [web] Added docs on jupyter notebook generated web pages. 7bfbc49
