Development IDEs
Overview
Here is a small compilation about debugging tools and how to set them up to start developing OGS. There are several development IDE’s available, both open-source or commercial. Some are multi-platform, others are platform-specific.
Here is a link list without specific order:
The steps to get things started with an IDE basically include generating the project files, importing them in the IDE and know where to provide arguments to the debugging binary.
I will assume, that you have the sources (eg. checked out from github) and that they lie in the source directory
Please, create a seperate build directory for your favorite IDE like
GDB
https://www.sourceware.org/gdb/download
Screenshot
Create project files
  1. CD to the build directory
  2. Generate project files with CMake:
  1. Start gdb in graphical mode, without license info (quiet) and with arguments:
  1. Have fun…
Documentation: https://sourceware.org/gdb/onlinedocs/gdb/index.html
Eclipse
http://www.eclipse.org/downloads
Choose “Eclipse IDE for C/C++ Developers”
Screenshot
Import Code
  1. Open Eclipse and choose File - Import - Existing Project into Workspace
  2. Select the build directory and click Finish (Attention: Make sure to not check the option Copy projects into workspace!)
  3. To provide arguments, you will have to run the project once: Run - Debug (running will start building first, if not already done).
  4. Then, give arguments via Run - Debug Configuration - C/C++ Application - ogs. Choose Arguments tab on right side and add your arguments to the line C/C++ Application, e.g.
  1. Start debugging…
Documentation: http://wiki.eclipse.org/Main_Page
Code::Blocks
http://www.codeblocks.org/downloads
or
https://code.google.com/p/fortranproject
The latter includes already plugins for Fortran, in case you want to cross-compile.
Screenshot
Import Code
  1. Open an existing project and choose before created .cbp file
  2. Choose your compilation target
  3. Give arguments: Project - Set Programs’ Arguments, select correct target and add Program arguments in the bottom
  1. Rock the show…
Documentation:
NetBeans
https://netbeans.org/downloads
Screenshot
Import project files
  1. Open NetBeans
  2. Choose File - New Project - C/C++ Project with Existing Sources (Click Next >)
  3. Specify sources directory, select configuration mode Custom
  4. Check Run Configure Script in Subfolder
  5. Click Next > until Finish
  6. Give arguments via Run - Set Project Configuration - Customize
  7. Under Run, give Run Command on right side:
  1. When starting debugging, choose correct target
  2. Have a great time…
Documentation: https://netbeans.org/kb/index.html
CLion
Download: https://www.jetbrains.com/clion/
Screenshot
Import project
You don’t need a build-directory for CLion. It will create it by itself.
  1. File / Import Project
  2. Choose source-directory
  3. When prompted do not overwrite CMake file, instead choose Open Project
  4. Under Run / Edit Configurations choose the ogs-target and set the program working directory and arguments
  5. On the top right choose the ogs-target and click the green Debug-button
Documentation: https://www.jetbrains.com/clion/help/introduction.html
This article was written by Marc Walther. If you are missing something or you find an error please let us know. Generated with Hugo 0.53. Last revision: February 26, 2018
Commit: [web] Finished development workflows section in devguide. 88ba0e067  | Edit this page on
Creative Commons License | Privacy policy / Legal statements / Impressum
