Working on Eve
Introduction
Members of the Department Environmental Informatics of the Helmholtz Centre for Environmental Research - UFZ can use the frontend1- and frontend2-machines from the Eve cluster system.
You need to opt-in to use the [EasyBuild modules](https://wiki.ufz.de/eve/index.php/EasyBuild)! To do so follow these steps:
  • Login to frontend1 or frontend2
  • Run touch ~/.easybuild-yes
  • exit and re-login
Also on eve the installed git module (2.10) is over 2 years old and we recommend using a newer module:
ml use /global/apps/modulefiles
ml git/2.20.1
Run OGS within a container
Eve has Singularity container runtime installed so you can simply download a prebuilt container and run OGS inside it. See the user guide for more infos.
Build OGS-6
Load required modules by sourcing the environment script:
source scripts/env/eve/cli.sh
Then do the build configuration and build the project.
Optional steps
Install and use Conan
Follow the instructions on using Python’s virtualenv on the Eve-wiki for setting up a local Python environment. Then you can pip install conan and use Conan.
Additional Features
Generating Doxygen documentation:
module load Doxygen/1.8.14
You can build with Ninja:
module load ninja/1.9.0
Build OGS-5
module load CMake/3.11.4
module load GCC/6.4.0-2.28
This article was written by Lars Bilke. If you are missing something or you find an error please let us know. Generated with Hugo 0.79.0. Last revision: May 11, 2021
Commit: [ctest] labels and timeout for OgsTest(). 989a41ea13  | Edit this page on
