Working on envinf1
Introduction
Members of the Department Environmental Informatics of the Helmholtz Centre for Environmental Research - UFZ can use the envinf1-machine which is tightly connected to the Eve cluster system.
On envinf1 the installed git module (2.10) is over 2 years old and we recommend using a newer module (especially when you have problems with fetching or checking out of Git LFS files):
Build OGS-6
Load required modules by sourcing the environment script:
Then do the build configuration and build the project.
Build the Data Explorer
Install and use Conan
Follow the instructions on using Python’s virtualenv on the Eve-wiki for setting up a local Python environment. Then you can pip install conan and use Conan.
Additional Features
Generating Doxygen documentation:
You can build with Ninja:
Build OGS-5
This article was written by Lars Bilke. If you are missing something or you find an error please let us know. Generated with Hugo 0.53. Last revision: February 14, 2019
Commit: [web] Removed help on GitLab LFS setup. 6903a3792  | Edit this page on
Creative Commons License | Privacy policy / Legal statements / Impressum
