Using ccache
GCC-like compilers only
Tested on GCC and Clang.
Introduction
ccache speeds up compilation times by caching object files and reusing them on subsequent builds. This even works for complete rebuilds (i.e. deleting the full build-directory). If ccache is found on the system it is automatically used.
Configuration
Add the following line to your ccache config file which is required for pre-compiled headers:
sloppiness = pch_defines,time_macros
See the ccache docs for other available options.
ccache and Clang
Set the option run_second_cpp = true or export CCACHE_CPP2=true to suppress lots of false positive compiler warnings.
Usage on envinf1
Just load the module:
module load /global/apps/modulefiles/ccache/3.3.3
This article was written by Lars Bilke. If you are missing something or you find an error please let us know. Generated with Hugo 0.53. Last revision: January 10, 2019
Commit: [web] Use regular or light icons instead of bold. 3f5734eb6  | Edit this page on
Creative Commons License | Privacy policy / Legal statements / Impressum
