Redistributable builds
Introduction
If a binary runs on a different machine depends on a lot of factors. The following sections provide some tips to maximize portability. In general Windows binaries are more portable than *nix binaries.
CPU Architecture Optimization
Default compiler flags
  • /favor:blend: Optimizes for AMD and Intel architectures, see MSDN docs
  • /arch:sse2 on 32-bit, /arch undefined on 64-bit
Optimization CMake options
  • -march=native: Optimizes for current cpu
CMake options
For redistribution
  • OGS_CPU_ARCHITECTURE: set to generic for good balance between optimization and portability; set to core2 for maximum portability, more info on gcc docs
For optimization
  • OGS_CPU_ARCHITECTURE: tot to native for best optimization for your current cpu, possible values are listed here, more info on gcc docs
  • OGS_ENABLE_AVX2: boolean (sets -march=core-avx2 when set to true), requires at least Haswell processors
See Linux-tab!
Shared vs. static libraries
Try to use static libraries as much as possible. For OGS itself use BUILD_SHARED_LIBS=OFF, which already defaults to OFF.
Third-party libraries installed via the systems package package manager are often provided as shared libraries. You may want to use Conan which provides lots of libraries (e.g. VTK) as static libs.
Package the build
Use the package-target which tries to gather all dependencies and fixes up shared library paths:
make package
This creates a zip- or tar-archive which should be redistributable.
This article was written by Lars Bilke. If you are missing something or you find an error please let us know. Generated with Hugo 0.79.0. Last revision: May 11, 2021
Commit: [ctest] labels and timeout for OgsTest(). 989a41ea13  | Edit this page on
