A recent version (1.32.1) of Conan is required! Please update Conan by running pip install --upgrade conan
or by downloading the Windows installer.
The Conan package manager helps to install all required libraries in a convenient way on every platform. See Setup pre-requisites for installation instructions. If the Conan executable is found Conan is used for third-party library handling. Set the CMake option OGS_USE_CONAN=OFF
to disable Conan.
Per default when Conan is enabled it will try to fetch prebuilt binaries from the OGS Conan repository at https://ogs.jfrog.io/ogs/api/conan/conan. With the CMake option OGS_CONAN_BUILD
you define what gets build locally. This option can be set to:
missing
- Default, only builds packages which are not available as a prebuilt binary for the current configurationall
- Builds all packages locallynever
- Builds no package locally[a list of libraries to build]
, e.g. "Eigen3;Boost"
. For names see ConanSetup.cmake. Make sure to set this back to ‘never’ after the libs have been built. Otherwise it would rebuild the libs on the next CMake run.Conan creates a runtime environment automatically. When activated this sets environment variables such as PATH
or LD_LIBRARY_PATH
to point to the used Conan packages. Can be activated in your build directory after CMake ran:
source activate_run.sh
source deactivate_run.sh
Generated with Hugo 0.79.0. Last revision: December 26, 2020
Commit: [PL/LIE] Subst. MaL::Vector3 by Eigen::Vector3d. d9c9d51c60
