We simulate a three point bending test performed on Rockville granite as shown below. Details of the experiment can be found in Tarok et al. 2017.
Developed crack (phase-field) and the crack mouth opening displacement (CMOD) vs. the force are shown below.
The model is able to simulate up to the brittle elastic failure, but as cracked surfaces are currently treated as frictionless, the behavior after the failure deviates from the experiment results.
Generated with Hugo 0.79.0. Last revision: October 16, 2020
Commit: [Process/TRM] Added the process creator 753da562c
